Powerview (Luxaflex / Hunter Douglas) - missing devices in scenes
I've installed a number of Sun blinds, which are controlled with a Luxaflex/Hunter Douglas PowerView system, all working well
I've installed the PowerView plugin on my HC2. Each PowerView-scene now shows up as a device on my HC2, and I can activate the PowerView scenes from the HC2 interface, so far so good.
However, when I try to build a Fibaro-scene (with magic scene or block scene builder), those devices do not show up in the device list selector and as such cannot be selected into the scene.
I would like to build a few Fibaro scenes like when the light intensity or temperature in the room gets too high, the blinds close automatically.
Has anybody have any experience with this?  I can still build a LUA script for this, or by-pass the Fibaro PowerView plugin and instead directly control the PowerView api with a number of VD's, but I was hoping that I could build a number of simple scenes.
The only way to control PowerView in block scene is using a VD. You can check the Knowledge base or marketplace.
It's very easy to configure.
  • 1 year later...
Hi @pnutp0werP!
Is there anything like this available for HC3?
thanks!
Edited by s.burger
  • 3 months later...
Have you solved this for HC3?
No there is no quickappyet, but you can control it by LUA scene or make a quick app to use it in block scenes.
