Fibaro lua script cycle
I have question about fibaro LUA script loops.
I have this situation:
When person prepare to leave house, he click button which turn on lua script cycle. When person back and click again, lua script cycle should stop. How i can do that?
hi, I do it like this,
341 is Fibaro dubble relais operated by push button
Create GLobal Variable  in my case
GastBoven  with value yes and no
GastBoven>>GuestUpstairs
JA>>yes
nee>>no
Boven gast aanwezig>>Upstairs guest present
%% properties
341 value
%% weather
%% events
%% globals
--Debug message(jgab)
function debug(color, message)
     fibaro:debug(string.format('<%s style="color:%s;">%s</%s>', "span", color, message, "span"));
function traceFibaro(name)
  local orgFun=fibaro[name]
  fibaro[name]=function(f,...)
    local args={...}
    local res={orgFun(f,table.unpack(args))}
    print(string.format("fibaro:%s(%s)%s",name,json.encode(args):sub(2,-2),#res>0 and "="..json.encode(res):sub(2,-2) or ""))
    return table.unpack(res)
traceFibaro("getValue")
traceFibaro("getSourceTrigger")
traceFibaro("getGlobalValue")
--------------- Use function----------------------------------------------------
debug("red", "Gast boven ja of nee");
-- Use colours like "white", "orange", "white, "green", "grey", "red", "blue".
debug("orange","scene start")
--here to start with scene
if
 ( tonumber(fibaro:getValue(341, "value")) > 0 )
then
    fibaro:setGlobal("GastBoven", "Ja");
 debug("yellow", "Boven gast aanwezig")
elseif
 ( tonumber(fibaro:getValue(341, "value")) == 0 )
then
    fibaro:setGlobal("GastBoven", "Nee");
  debug("yellow", "Boven (geen) gast afwezig")
debug("orange","scene beeindigt")
