Sjakie 157
Hi Guys,
Here I am again!
If you are using global variables in a scene I cant do that or the system does not allow me or I am doing something wrong.
I have the complex devided in 3 parts and created the GV's:
GV
house : present away
upstairs : present away Remark: different persons in 3 posibilities
outside : present away
to "arm" it will become a combination of above house is always involved
I create one scene to include all for example:
if
( fibaro:getGlobalValue("house") == "present" )then
elseif
( fibaro:getGlobalValue("house") == "away" )then
elseif
( fibaro:getGlobalValue("upstairs") == "present" )then
elseif
( fibaro:getGlobalValue("upstairs") == "away" )then
elseif
( fibaro:getGlobalValue("outside") == "present" )then
elseif
( fibaro:getGlobalValue("outside") == "away" )then
It will not work only the first mentioned GV in header will be executed.
I changed also elseif in if
I tried the GV one by one in a seperate scene and that works.
Where I go wrong????
Thanks in advance for the help.
