slawomir 0
Sorry for my english
I have UBS with 4 temperature sensors that I installed on the heating pipes.
Two pumps from heating (one main and the other to the floor roller) are connected via Double Switch 2.
I have constructed scenes that:
1. after reaching one sensor ( heating supply), the temperature of 55 degrees switches both pumps on
2. after the temperature drops below 45 degrees, it switches off the central heating pump
3. after the temperature drops below 40 degrees, it switches the pump off from the floor heating.
Before updating to the latest version of the HCL head office software, the scenes were running all the time, and now they do not run all the time after the update. I mean, when I restart the control panel it will work once and not once. I do not know what's going on
Are the scenes badly constructed or something wrong with the HCL headquarters?
1.
2.
3.
One more additional question, why on some of the scenes that work without a problem is the text Run instances: 1 and an other does not have ?? Does it mean that it does not work?
