Karel79 0
Hello everyone,
i bought a Fgs-222 and I tried to add it to Homeassistant. The first time it worked but I had some issues for which I add to remove the device and now when I try to add it again I don’t manage to do that anymore. When I click on add secure node in HA I can see the following lines in OZW_Log.txt:
19-04-05 19:52:37.618 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK: 2019-04-05 19:52:37.618 Info, contrlr, ADD_NODE_STATUS_DONE 2019-04-05 19:52:37.618 Detail, Node006, Expected reply was received 2019-04-05 19:52:37.618 Detail, Node006, Message transaction complete 2019-04-05 19:52:37.618 Detail, 2019-04-05 19:52:37.618 Detail, contrlr, Removing current message 2019-04-05 19:52:37.618 Detail, Notification: ControllerCommand - Completed 2019-04-05 19:52:41.887 Detail, Node014, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x0e, 0x06, 0x31, 0x05, 0x03, 0x0a, 0x00, 0x00, 0xc2 2019-04-05 19:52:41.887 Detail, 2019-04-05 19:52:41.887 Info, Node014, Received SensorMultiLevel report from node 14, instance 1, Luminance: value=0lux 2019-04-05 19:52:41.887 Detail, Node014, Initial read of value 2019-04-05 19:52:41.887 Detail, Node014, Notification: ValueChanged 2019-04-05 19:52:42.442 Detail, Node027, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x1b, 0x03, 0x25, 0x03, 0x00, 0xcc 2019-04-05 19:52:42.442 Detail, 2019-04-05 19:52:47.732 Detail, Node027, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x1b, 0x03, 0x25, 0x03, 0xff, 0x33 2019-04-05 19:52:47.732 Detail,
The device I am trying to add is Node027. As you can see there is some info received from the device but still it does not get added to HA. What should I do? How can I fix this? Thanks
Karel
