Ultimattum 0
Hello all,
I'm trying to configure a Popp Keypad as a user code reciver to check the code by fibaro LUA, not as an arming alarm panel. My objective is to change codes remotely and those codes checked by the home center to open (or not) a door.
Popp Keypad seems to work a security devices when added to home center 2, so you must put pins in his config panel from fibaro devices or set them by lua code.
/monthly_2019_04/image.png.928cf4c70a97203d3808109625826b1d.png" alt="image.png.928cf4c70a97203d3808109625826b1d.png" />The command is: fibaro:call(id, "setUserCode", "1", "Available", "9999", "");
The problem is, when i call this command, the Popp Keypad waits a Wake Up, so when i wake up it manually the pin config panel from fibaro stucks himself and the command: print(fibaro:getValue(id, "userCodes")), prints me an ethernal "update":"InProgress"
If i refresh the page, the synchonization seems stuck and dont let me writte any pin manually, so i have to resynchronice again losing any pin code set.
In other words, im unable to st pin codes by LUA in my Popp Keypad.
Anyone knows how to solve this?
5 answers to this question
