Smart implant outputs hidden after reboot!
samuel
I deselected the two outputs as not hidden in the advanced tab
After reboot of the HC2, the two outputs are again set to "hidden" device
How to solve this?
This is the same for the RGBW modules, but by the RGBW modules I am not able to make them "hidden"
HC2 - 4.540
Smart Implant firmware 5.1
How to solve this?
I think is has to do with your input configuration.
/monthly_2019_04/image.png.0c6e11442bbd34c75224b570fd6eb614.png" alt="image.png.0c6e11442bbd34c75224b570fd6eb614.png" />
When you select a binary input it uses another slave device then when you set to 'not used'. The slave device which is not in use, will be hidden.
Yeah, I've got the same. I've put the module in the unassigned room so it will not displayed in the new Home Center app.
