Sjakie 157
Hi Guys,
I noticed something weird the scene is as below. Let me explain I have a program to control our heater. It is running 5 different temperature levels at this moment.
GV Dagdelen Avond>>Evening
Stookseizoen ja>>> Heater season Yes
LocatieGezin aanwezig >>family Present
351 Door
At 6 "o clock, start of the evening this scene was executed!!!!!!!!! Door value is actual 0(Unfortuanally I changed some text in the scene thats why I lost the actual Debug window where was shown the call by Sonos and the http order. I checked it in the heater. This was fast overwritten by the scene I have if door goes open.
In my believing the scene should stop is one argument is not present.
This happends more yesterday another scene where something got executed while the argument was not according the trigger
How is this possible?
Still running 4.53 affraid to update
/monthly_2019_04/image.png.d121c07d5a86269e8dc7dbbea7349bc5.png" alt="image.png.d121c07d5a86269e8dc7dbbea7349bc5.png" />--[[
%% properties
351 value
%% weather
%% events
%% globals
Dagdelen
Stookseizoen
LocatieGezin
function debug(color, message)
fibaro:debug(string.format('<%s style="color:%s;">%s</%s>', "span", color, message, "span"));
function traceFibaro(name)
local orgFun=fibaro[name]
fibaro[name]=function(f,...)
local args={...}
local res={orgFun(f,table.unpack(args))}
print(string.format("fibaro:%s(%s)%s",name,json.encode(args):sub(2,-2),#res>0 and "="..json.encode(res):sub(2,-2) or ""))
return table.unpack(res)
traceFibaro("getValue")
traceFibaro("getSourceTrigger")
traceFibaro("getGlobalValue")
debug("orange","scene start, Verwarming op nachtstand als deur eetkamer naar serre is geopend")
local DeurnaarSerre = 351
if
( fibaro:getGlobalValue("Dagdelen") == "Avond" )
and
( fibaro:getGlobalValue("Stookseizoen") == "Ja" )
and
( fibaro:getGlobalValue("LocatieGezin") == "Aanwezig" )
and
( tonumber(fibaro:getValue(351, "value")) == 0 )
then
--aanroepen http request
local http = net.HTTPClient()
function call(url)
http:request(url, {
options = { method = 'GET' },
success =function() fibaro:debug(url.." ,done.") end,
error = function(errorcode) fibaro:debug("error=" .. errorcode) end
call("http://192.168.1.101/data.json?heater=0&setpoint=171&thermostat=0")
-- 279 is the Virtual Device ID
-- 28 is the Process button ID
local sid, bid = 249, 28
-- Create TTS params object
local params = {
-- TTS Message
message = "Hallo, Saartje zet de verwarmingsthermostaat naar comfort avond 22,1 °C",
duration = 'auto', -- Duration: "auto", xx seconds
language = "nl-nl", -- Language: fr-FR
volume = 50 -- Volume
local _f = fibaro
local _x ={root="x_sonos_object",load=function(b)local c=_f:getGlobalValue(b.root)if string.len(c)>0 then local d=json.decode(c)if d and type(d)=="table"then return d else _f:debug("Unable to process data, check variable")end else _f:debug("No data found!")end end,set=function(b,e,d)local f=b:load()if f[e]then for g,h in pairs(d)do f[e][g]=h end else f[e]=d end;_f:setGlobal(b.root,json.encode(f))end,get=function(b,e)local f=b:load()if f and type(f)=="table"then for g,h in pairs(f)do if tostring(g)==tostring(e or"")then return h end end end;return nil end}
-- Make a request to the remote to process params object instantly
_x:set(tostring(sid), { tts = params })
_f:call(sid, "pressButton", bid)
debug("orange","scene beeindigt")
