REST API call action set value
Why the rest api document not include the method to set value?
there is a method in lua document to do this
-- non-parametric 'turnOff' action call of id=12 device fibaro:call(12, 'turnOff');
-- 'setValue' action call with one additional parameter fibaro:call(12, 'setValue', '23');
Call Action
URL: /api/devices/deviceID/action/actionName deviceID – ID of an existing device
actionName – Name of an action
Methods: POST
Description: Trigger an action of the specified device
Response:
and when I call http://xxxxxxxx/api/devices/12/action/setValue
it returns error
    "error": {
        "code": -1,
        "message": "Exception: Server error"
    "id": 1,
    "jsonrpc": "2.0"
So, how to pass the actionName with the value in rest api....
waiting for your response, thank you very much!
    I found the solution
    set the body
      "args": [23]
    you can use as follow
    http://hc2/api/callAction?deviceID=792&name=setBrightness&arg1=40
    Thank you very much~ in the api document, I can't find this GET api way called callAction in
    hc2
     and the pdf doc
    Does there is any other more complete document for the REST API ?
