hjd 0
I can query a device (a com.fibaro.doorSensor) via the API with a call to: http://fibaro/api/devices/<deviceID>
From this I can pull the properties.lastBreached value (an epoch count in seconds) which is the time the door was opened.
I can't see any way to pull the value of when the sensor went safe (when the door closed). It must be somewhere, since the UI shows it.
Any ideas?
