Problem adding RGBW to H2
gunnarh
I have two RGBW  2.5 and both are connected to one white led strip but when i try to add them to H2 noting happens
  • I have tried to add it with push add bottoms on H2 and connect the power to the RGBW.
  • I have tried triple bush on B bottom after pressing add device on H2.
  •  I have reset the RGBW with pressing B bottom and connect the power and the release the bottom.
  • I have change the 12V power supply.
I did try add other device like single switch and no problem.
What is next?
Edited by gunnarh
15 answers to this question
I have the same problem with both of my new bought rgbw moduls. As  gunnarh, I tried to include them several times, did a reset, placed them near the HC2. However I cannot include them to my z-wave network...
I am running the latest version on my HC2. Are there any hints how to get them running? Thanks!
  • @akatar  It have never been added to controller because it have never work. To be sure i did search for it in the controller and did not find it.  I did do factory reset on the  RGBW device and the B channel blinks but same problem. It will not add to the controller. I did add Single switch last night without problem.
    Thanks for this input.
  • Not sure how i can remove it when i can not add it.
  • @akatar Yes i have test this and nothing happen, did try that again and same result.
    Edited by gunnarh
    Hi @gunnarh,
    If even exlusion (removing) of device does not help and it works for other devices, then please, proceed with RMA of those devices.
    PS: My method of detecting wrong component.
    1. Check if its Z-Wave or HK device. -> yes, i know how stupid this sound, but people do stupid things sometimes.
    2. Check if frequency of device and HC. Have to match.
    3. Try to remove device via Devices - Add or remove device - Device to remove -> Removing via Z-Wave is factory reset via radio and it could be apliable to devices from different Z-Wave network.
    4. Change battery and do nr. 3 again.
    5. Restart HC and do nr. 3 again.
    then check powersupply, 12vdc or 24vdc and check if positive is correct
  • @akatar I have tried two 12vdc and last night i did try 24vdc. I did use multi meter to check positive.
    On ‎9‎/‎2‎/‎2019 at 2:14 PM, jakub.jezek said:
    Hi @gunnarh,
    then this….
  •  I did check you list and same result, i will try to get access to another Fibaro HS2 and test it there.
