Making a Scene automaticly activate (solved)
Hi, I'm having trouble getting my scene to activate automaticly when a action is done. I have to manually click "start" for the scene to begin.
21 = my Hue lamp
27 = Fibaro switch
I want the switch to turn on automaticly when the Hue light is turned off, and vice versa.
Edited by imLiquid
8 answers to this question
I see you're checking not "value", but "on" state... is it correct?
I think in this case you need to set as follow
Please verify the device (21) properties...
In browser type follow link
http://hc2IP/api/devices/21
Edited by cag014
    @10der Sorry I also had the top bit, just forgot to post it.
    thought when it was grayed out it was not active.
    so basicly you posted the same code as mine.
    @cag014 This is correct. because it's a Hue light.
    value of "on" is true or false
    and the change to
    worked perfectly :D. thank you so much.
    On 4/15/2019 at 8:07 AM, 10der said:
    Since im still practicing with LUA, i wanted to ask..
    is the " local startSource = fibaro:getSourceTrigger(); " needed in this case even if it is not used as part of the scene?
    example for using :getSourceTrigger
    [two switches - one lighting]
    So in a case where i am using a global variable and one device value to trigger a scene, the startSource would not be very important?
    8 minutes ago, 10der said:
    For the countScenes, is there a difference if we set it inside the code or through the scene main page using the max instance drop down?
    I am actually having a problem with a scene that runs sometimes and sometimes does not
    Any idea what might be the problem?
    After a reboot to the HC2, all is working fine now!
    Thanks for the help!
