I cannot seem to get my alarm to work.
Scene 1 Alarm on.
Scene 2 alarm goes off
Scene 3Alarm off
what am i doing wrong here?
5 answers to this question
you have put all the sensors in a group and said if ALL the sensors are breached then alarm will activate.
you need to list them individually and use the OR command between the sensors.
    Thanks Morpheus75..
    But witch setting should i be using?
    /monthly_2019_04/1097426855_Schermafbeelding2019-04-16om19_25_26.png.7bd3c113602afc476d1540857c05cfea.png" alt="1097426855_Schermafbeelding2019-04-16om19_25_26.png.7bd3c113602afc476d1540857c05cfea.png" />
    Hi @Cobraman
    You need geactiveerd en ingeschakeld (breached and armed). And as @morpheus75 already said use the OR command between the sensors. The alarm will be activated when one or more sensors are breached while the alarm is active.
    Edited by kevin
    1 minute ago, kevin said:
    Hi @Cobraman
    You need geactiveerd en ingeschakeld (breached and armed). And as @morpheus75 already said use the OR command between the sensors. To the alarm will be acted when one or more sensor are breached while the alarm is active.
    thanks. i would have needed google translate to work it out!
    Thank you very much guys you have been a great help.
