It's time to dramatically update the Virtual Device
Hi, Fibaro developers!
This is my cry from the heart.
More than a year passed since this post was published:
And it still has no answer as well as any Fibaro reaction.
And it is 2019 now, but Virtual Device in Fibaro still has no ability to add such simple ordinary objects like [Image] or [Checkbox] !!!
1) A Slider can be much more useful having a customizable range (0-100 between the ends is normal for gates or rollers, but it is absolutely unuseful, for example, for thermostats, where 15 - 40 range is ideal).
2) It is madness to use two Buttons + Label instead of one Checkbox...
I have to do this:
Notifications: Enabled   <-- Label
[Enable] [Disable]  <---- Buttons
Instead of this:
[X] Enable Notifications
3) Image is absolutely vital for displaying Album art (multimedia control), Weather forecast (temperature control) etc. I even not say about Animated (OMG!) GIFs (to displaying some processes).
Sure, I can use html tag <img src='...'> and put it as Label value, but it will work only in Web version and this is insane at all!
These are absolutely elementary things and I don't understand why I am asking to add them since 5+ years of Fibaro's presence on market.
I hope you will hear me, Fibaro developers and programmers.
Kind regards,
Vasyl
This could be another very good topic at the poll section of the forum, if fibaro will ever make use of it
Edited by StefanS
Unfortunatelly is like fibaro has no support for adding new features or improvements! So guys is just loosing of time to ask things! They won't do something for these i think...
  • 2 months later...
thank you for your suggestions!
When it comes to this feature I have submited your request.
I have to do this:
Instead of this:
Could you please elaborate more on this one? I am not entirely sure what you are thinking about.
Do you have an idea how to solve this? Where would you like to store images for albums, should that be as icons or do you have something else in mind? I need more information how would you like this feature to work.
    Thank you, will wait.
    Take a look on a virtual device (leakage protection, automatically closes water valve as well as sends notifications to inhabitants) on a real object:
    You have also generated a great idea regarding animated icons. They are can be stored in a HC (as well as usual user icons) but they must be just usual animated GIFs 128x128px size.
    It would be nice if some devices with moving parts (pumps, fans etc) will use some animated picture when are ON.
    Thank you for your feedback. Better late than never. I hope you will use Fibaro community request for further improvements.
    I can suggest to use node-red plus node-red ui
    Well, it is good to have all possible options ready made, however it is not cosmic science to have customised values for the sliders.
    Here is an example of the code to have different range of slider value (start and end values) as well as customised step :
    I like also to see a dropdown control on VD, to select content of enum variable.
    Instead of checkbox i prefer switch icon. Does the same, but looks better :)
    image.png.fe0f69395c2bbe028ba088b52519233f.png OR image.png.570503c9f5795e02d3d3cda739592f56.png
    And i wish there were more main buttons available. Just like it is in predefined/physical devices.
    Edited by pogo
