Calculating Times...
Dear all,
I want to develop a customized presence simulation for my home. Therefore, I need to calculate with hours, but I don't know how to manage that in LUA. ;-)
Could someone help me, please?
I want to randomize a number between 1 and 10 and add this as minutes to the official SunseHour (For example 19:34 + 7 = 19:41). I tried that:
That doesn't work..... could someone help me, please?
Thank you so much for your answer.
Dan
11 answers to this question
    Great, thank you very much!!
    @jgab One more question.... based on your script, I generated the "randomized" global variables Presence_Sunrise and Presence-Sunset.
    In another script, I want to show this times and add a number of minutes (here called "Fernsehzeit") to this time and print it again. Unfortunately, that doesn't work because it seems that it's not saved as time-value.
    Could you probably help me how I can fix that? Thank you so much!!
    And I also want to add a auto-start trigger, when the global saved Start-Presence time is reached....
    How can I use here the Presence_Sunset-Variable as trigger when it should start?
    Thank you so much!!
    Dan
    Edited by Danielos
    Ok, this is an alternative...
    str2sec(<time-value>) converts a time-value string to number of seconds. This allow you to do arithmetic with the values
    sec2str(<number of seconds>) converts back to time-value string
    To generate your two sunset/sunrise values
    Then in the other script
    Ok?
    The answer to your second question, how to trigger on the values, I recommend a previous post on the topic
    The tonumber() function there is similar to the str2sec() function presented here.
    The scene runs every minute and you can do tests inside the clock() function to see if its's time to do actions
    Thank you, @jgab. Your code is much more complicated than mine - I see the difference between a newbie and a pro. :-) Thanks for your help!
    Now, one last part is missing for my script based on your suggestions.  I "overwrited" the official sunset time as demo. In this case with 10:15. And I want to check minutely, if the current time is 10:15 and if yes, print a text. Unfortunately, none of my 3 syntax worked.... ;-) I'm sure it's only a little mistake...but I can't find it. Any ideas?
    Ok, the clock() function is called every minute with the arguments you need
    Ex. clock("15:01","06:00","20:0","Monday",false)
    Where 15:01 is the current time (updates every minute of course), 06:00 and 20:00 is the sunrise and sunset values (changes every midnight), day is a string with the day name according to the table provided, and false is false if it is a weekday otherwise true.
    That means that if you have your values in time-value strings like you have in your globals you can just test with equality (==)
    I also recommend you to do fibaro:getGlobalValue("Presence_Sunset")==time so the loop will start to test against the new Presence_Sunset if you updates its value.
    I also think you should skip the addTime and use the sec2str and str2sec in my last example. str2sec is the same as the 'tonumber' provided in the code.
    I added a log in the beginning of clock to print the values.
    Have you tried to run it in my emulator? The _System.speed(true) in the beginning of the scene runs the scene quicker than realtime so you can see if you trigger at the right times without having to wait hours...
    @jgab you're brillant!! Thank you very much, now everything works as I wanted it.... and I learnt a lot I can reuse for other scripts. Thank you so much!
    @jgab: The scene works brillant... but because of the large time difference of the sunset time in summer time compared to winter time, the function isn't perfect at the moment. Therefore, I want to calculate the start better. Unfortunately, I still don't feel me comfortable with the time calculating functions. Could you help me how the string is for that case:
    1. A calcuation, how many minute are between 22:00 and the official sunset time (example: if the sunset time is 20:30, the time difference until 22:00 is 90 minutes)
    Thank you very much in advance.
    gives you the minutes between sunset and 22:00 (if you run it inside the clock function the variable 'sunset' is set to the sunset time).
    If sunset happens after 22:00 (as it does in Scandinavia) it will return a negative value (you can use math.abs() to get the absolute value.
    Hi Can anyone help me please? I am trying to calculate a time as follows, I need split the day in to 12 hours depeding on sunrise and sunset time and then calculate one and a half of these hours before sunset.
    So far I have the following:
    My Scene at the moment:
    local fmt = string.format
    function str2sec(str) local h,m,s=str:match("^(%d%d):(%d%d):?(%d*)") return 3600*h+60*m+(s~="" and s or 0) end
    function sec2str(sec) return fmt("%02d:%02d%s",math.floor(sec/3600),math.floor((sec % 3600)/60),sec % 60 > 0 and fmt(":%02d",sec%60) or "") end
    local SunRiseTime = str2sec("07:06")
    local SunSetTime = str2sec("17:31")
    local Plag = sec2str(SunSetTime - (string.format("%.0f",(((SunSetTime - SunRiseTime) /12) * 1.25)))) -- "16:25:54"
    Question:
    How can i round the results to only minutes and round up at 30 seconds?
    In the above example I would want to get "16:26"
    Thank you for any help provided
