It seems like setTimeout can only handle ms values less than or equal to 2147483648-1 (~24 days)
Try
If you need to set timers further into the future you need to patch setTimeout and clearTimeout
Updated with correct values thanks to @petergebruers
so max is 6 * 2^30, set Timeout is based on boost:asio, posix time overflow?
    Maybe, but why 6 * ... and why not 2^32-1 ?
    Interesting question. Not a clue, that number seems a bit weird, but I guess in the end they are kernel timers and I am reasonably sure their resolution is ns and range is 64 bit.
    cat /proc/timer_list|grep LuaEnv -A 1
    Those might me the timers I use in Lua...
    I am not an expert on this, but I deduce the kernel timers use ktime_get so monotic time... Which may be good or a bad thing depending on what you want to do, eg do you care about DST changes? The Linux docs tell me "Useful for reliable timestamps and measuring short time intervals accurately. Starts at system boot time but stops during suspend.". If you want to measure 1 day I guess sometimes that means "exactly 24 h from now on" and sometimes it means "at exactly the same 24 h clock time" which in most cases is quite the same (when measuring 24 do we care about clock drift? Probably not.) - but not 2x per year or when people manually adjust the wall clock.
    Edit: of course @tinman and @jgab don't need me to tell them that... I try to write posts for a broader audience which might be unaware of the subtleties of time measurement and representation...
    Edited by petergebruers
    definitely wired number, on the other hand 74 days uptime is a lot :P
    :-D If Fibaro keeps doing HC (beta) firmware releases fast enough, I don't need 74 days.
    Well, in my emulator setTimeout behaves "better" and I provided a scene for a user that turns on/off lights at Earth Hour...next year... well it turned on and off the light in the middle of the night the other day :-) That's how I became aware of this strange behaviour. No guarantee that it actually works correctly for all values less than 6442450944, depending how it wraps/truncates... but at least it doesn't return immediately. Empirically, setTimeout seems to be well synched with os.time for periods of weeks at least, so I suspect they derive from the same "source". Hmm, what happens when it adjust the time with the (now working) NTP servers? I expect (Linux) timers adjust...or?
    Daylight savings is another story but they may soon be gone...
    This made me thinking... It probably uses a signed integer, somewhere, instead of an unsigned integer, 32 bit, then it suddenly becomes negative after 2^31.
    So 2147483648 -1 == 0x7FFFFFFF should work and 2147483648 == 0x80000000 should return immediately.
    Aha. That would mean rollover after 24.8 days.
    Good spot! Kick myself for not testing it - can't change title of the thread :-)
    and not we know where the 6*2°30 (or 1.5*2^32) is coming from :)
    ok, we need more than 74 24 days :P  image.png.ec2eecf94d3b2c944613ad066d4eb498.png
    Edited by tinman
