Hi, could you help me to create the following script for the management of an energy meter (WiDom Energy Driven Switch ver. C) on HC2?
At least for now it's really complicated for me.
  • 3kw max power threshold
  • exceeding 3kw ... the siren is activated immediately for 1 minute
So if:
  1. if the system load is not lowered manually within 1 minute, the energy meter disconnects the general, turns off the siren and tries to restore the system automatically up to 3 times the system (1 time each example 2 minutes).
  2. if I intervene by lowering the load, the siren turns off and the energy meter does not intervene.
 Thank you so much and excuse the very bad English
edit: damn it, maybe I got the wrong room! I kindly ask the moderators to include it in the appropriate one, thanks :oops:
Edited by GasDeKu
room error (sorry)
  • 11 months later...
hi, i have made this scene:
%% autostart
%% properties
388 value
%% weather
%% events
%% globals
if ( tonumber(fibaro:getValue(388, "power")) > 2500 )
then
  fibaro:call(384, "sendDefinedPushNotification", "375");
  fibaro:call(386, "sendDefinedPushNotification", "375");
