Z-Wave thermostat can’t be controlled in new app
After upgrading to the new app, I can’t change temperatures anymore. That goes for the Z-Wave thermostat in my bathroom as well as the Fibaro temperature sensor (smoke sensor) I'm using to switch a Fibaro wall plug on a living room heater.
Hei, i had the same problems with the new app . Ended up going back to the old . There are several posts on the forum about the problems with new app. Seems the software is not 100%
Edited by MARCUSP.I.L
    Thanks, Marcus!
    I did the same; reinstalled the old app. However, the temperature in the old app only has maximum 28°C setpoint. Do you (or anyone) know if there's a way to override this?
    Setpoint is registered/ innstilt in the device settings. You can't override in app. I first set up max and min values in the termostats , then confirmed these values in device settings. App won't allow you to change this.
    Note, careful when setting setpoint on heating, wooden floors -parkett , recommended max value 27c, i have dropped a little to 26c and set up scenes to warn me if someone (usually myself) mistakenly changes the max values.
    I am using termos, Heatit Z., but would imagine the set up is similar for all types ?
