Dman568 2
Hi All
I have the following code that that turns on my front door light when it is open and turns it off 5 minutes after it closes, this meets my needs most of the time but if some one leaves the house and wants the light on for their return it has turned off. What I want to do is abort the turn off if my global variable for occupy count changes. I was thinking i could take a count from the global variable run the scene then check 5 minutes later and if it has changed keep the light on or turn it back on. Anyone have any thoughts or sample code?
if (fibaro:countScenes()>1) then fibaro:abort(); end
if ( fibaro:getGlobalValue("TimeOfDay") == "Evening" )
and
( tonumber(fibaro:getValue(280, "value")) > 0 )
then
fibaro:call(291, "turnOn");
and
( tonumber(fibaro:getValue(280, "value")) == 0 )
then
setTimeout(function()
fibaro:call(291, "turnOff");
end, 5*60*1000)
6 answers to this question
