Motion lastBreached
Hi
I am trying to create a simple Virtual Device to show the elapsed time since motion on a number of sensors, I have the following updating a label
fibaro:call(335, "setProperty", "ui.Label1.value", tostring(fibaro:getValue(166, "lastBreached")));
Any idea how to convert the response of 1555934942 into time since last motion detected?
18 answers to this question
Like this ?
39 minutes ago, Dman568 said:
Hi
Could you share whole lua code with us please..
thanks
    12 hours ago, jgab said:
    Like this ?
    Thanks that is showing a time now but it inst the elapsed time, the last motion was an hour ago but that is showing 08:43:36
    To check what the last breached time was test
    and to be sure that you don't  have a really old lastBreached value
    Sorry, didn't think about dst.
    You need to do something like
    Cheers I have the following code in the mainloop
    function toTime(t) return string.format("%02d:%02d:%02d",t/3600,(t%3600)/60,t%60) end
    fibaro:debug(os.date("Time elapsed %H:%M:%S",os.time()-fibaro:getValue(166, "lastBreached")))
    fibaro:debug(os.date("Time now %H:%M:%S",os.time()))
    fibaro:debug(os.date("Last breached %H:%M:%S",fibaro:getValue(166, "lastBreached")))
    fibaro:debug(os.date("Last breached %c",fibaro:getValue(166, "lastBreached")))
    fibaro:debug(string.format("Time elapsed %H:%M:%S",toTime(os.time()-fibaro:getValue(166, "lastBreached"))))
    The debug output is
    [DEBUG] 15:13:52: Time elapsed 15:24:58
    [DEBUG] 15:13:52: Time now 15:13:52
    [DEBUG] 15:13:52: Last breached 07:48:54
    [DEBUG] 15:13:52: Last breached Tue Apr 23 07:48:54 2019
    [ERROR] 15:13:52: line 8: invalid option '%H' to 'format'
    time now and time last breached are correct but the time elapsed isn't. I can see it is just date manipulation but not sure what it should be
    Hi, I suspect line 8 invalid is the cause of your error
    print(os.date("Last breached %H:%M:%S",fibaro:getValue(166, "lastBreached")))
    ony end I see the difference between last breached and the present time
    Sorry, cut and paste error
    Perfect exactly what i was looking for, thank you so much for your help
    @Dman568
    I was looking for that because the mobile app doesn’t show the lastbreached time.
    Could you share the complete VD? And can I add more sensors to it so I can watch them all in 1 vd?
    thank you in advance.
    @Dman568  Wondering if you get the same screen as me ? Time displayed is always with hour set to 1 Minutes and seconds are correct but it always adds hour. Believe it has to do with left padded integer.
    Edited by MARCUSP.I.L
    7 hours ago, kevin said:
    @Dman568
    Here is my code, you need a label for each one on the VD
    fibaro:debug(os.date("Time now %c",os.time()))
    fibaro:debug(string.format("Time elapsed %s",toTime(os.time()-fibaro:getValue(166, "lastBreached"))))
    fibaro:call(335, "setProperty", "ui.Label1.value",string.format("%s",toTime(os.time()-fibaro:getValue(280, "lastBreached"))))
    fibaro:call(335, "setProperty", "ui.Label2.value",string.format("%s",toTime(os.time()-fibaro:getValue(276, "lastBreached"))))
    fibaro:call(335, "setProperty", "ui.Label3.value",string.format("%s",toTime(os.time()-fibaro:getValue(176, "lastBreached"))))
    fibaro:call(335, "setProperty", "ui.Label4.value",string.format("%s",toTime(os.time()-fibaro:getValue(262, "lastBreached"))))
    fibaro:call(335, "setProperty", "ui.Label5.value",string.format("%s",toTime(os.time()-fibaro:getValue(302, "lastBreached"))))
    fibaro:call(335, "setProperty", "ui.Label6.value",string.format("%s",toTime(os.time()-fibaro:getValue(326, "lastBreached"))))
    fibaro:call(335, "setProperty", "ui.Label7.value",string.format("%s",toTime(os.time()-fibaro:getValue(229, "lastBreached"))))
    fibaro:call(335, "setProperty", "ui.Label8.value",string.format("%s",toTime(os.time()-fibaro:getValue(166, "lastBreached"))))
    this is my VD
    I had finally the time to add this to my system. I would like to see the date and time it was breached for the last time. Not the time that is elapsed. Who can help me with the correct code to get this?
    Thank you in advance.
    Kevin
    Edited by kevin
    I tried a lot last several days but can't get it working like how I want it.
    Can someone help me? I don't want to see the elapsed time but the date and time when it was last breached.
    Kevin
    Kevin
    fibaro:call(335, "setProperty", "ui.Label1.value", os.date("%c",fibaro:getValue(280, "lastBreached")))
    fibaro:call(335, "setProperty", "ui.Label2.value", os.date("%c",fibaro:getValue(276, "lastBreached")))
    fibaro:call(335, "setProperty", "ui.Label3.value", os.date("%c",fibaro:getValue(176, "lastBreached")))
    fibaro:call(335, "setProperty", "ui.Label4.value", os.date("%c",fibaro:getValue(262, "lastBreached")))
    fibaro:call(335, "setProperty", "ui.Label5.value", os.date("%c",fibaro:getValue(302, "lastBreached")))
    fibaro:call(335, "setProperty", "ui.Label6.value", os.date("%c",fibaro:getValue(326, "lastBreached")))
    fibaro:call(335, "setProperty", "ui.Label7.value", os.date("%c",fibaro:getValue(229, "lastBreached")))
    fibaro:call(335, "setProperty", "ui.Label8.value", os.date("%c",fibaro:getValue(166, "lastBreached")))
    Thank you @jgab, I don't know why I didn't found this myself:oops:. I have added a line for a time format.
    Now it's looking great in the VD.
    Edited by kevin
    Thanks,
    You see that I use os.date("%c",<time>) to format the time. There are many more options besides '%c' that that can be combined and allow you to put together a format of your own choice.
    See
    Ex. os.date("breached at %b %d, %X")
    Results in the string "breached at May 19, 10:00:22"
