Sjakie 157
Hi Guys,
I have a scene strating if I am up, or afternoon or evening.what will switch on my fountain if two doors are open, no problem.
It will switch of after 90 minutes no problem.
It will start again because both doors are still open, how to stop this?
I only want one cycle when door is open, in other cases it will be started manually
Thanks in advanced
%% properties
347 value
351 value
%% weather
%% events
%% globals
Dagdelen
local GlassHousedoor = 351
local DiningoomDoor= 347
local Fountain = 228
if
( fibaro:getGlobalValue("Dagdelen") == "Opstaan" )
or
( fibaro:getGlobalValue("Dagdelen") == "Middag" )
or
( fibaro:getGlobalValue("Dagdelen") == "Evening" )
and
( tonumber(fibaro:getValue(347, "value")) > 0 )
and (tonumber(fibaro:getValue(351, "value")) > 0 )
then
fibaro:call(228, "turnOn");
elseif
( tonumber(fibaro:getValue(228, "value"))> 0)
then
setTimeout(function()
fibaro:call(228, "turnOff");
end, 90*60*1000)
elseif
( tonumber(fibaro:getValue(347, "value")) == 0 )
or (tonumber(fibaro:getValue(351, "value")) == 0 )
then
fibaro:debug()
