json.decode escape characters error
I want to make the virtual device's button that triggers the code that install another VDs in the system. I have a problem with decoding the JSON with VDs data, especially what's inside a main loop.
This is a raw JSON that comes from exporting the VD to vfib file (packed inside an array).
When I try to decode it with json.decode(virtualDevicesJson) I get the error message:
[ERROR] 19:25:52: line 145: Expected comma or object end but found invalid token at character 139
This is where the escape characters are. Is anyone had this problem and found a way how to avoid the errors?
    I've found a workaround.
    First I wanted to use api.post() method to create a VD. It forces me to decode JSON first.
    Then instead of api.post() I useNet.Fhttp().
    Hope somebody find it useful.
