Complicated Pond Script - calculate temperature
Hi there,
i use three scripts for my pond control and need your help with this.
In first script, time for global variable will be calculated.
I got 4 values in my variable named "Teich": Day, Night, Winter and Stop. Time calculation for "Day" and "Night" is working but now i need mean value calucaltion from three water temperature sensors that are connected to a smart implant. ID´s for sensors are: 390, 391, 392
For this the variable "Winter" should be activated when water temperature is under 8 degress over 2 days.
If water is 8 degress or higher for 2 days, time based variables "Day" and "Night" should be working.
Note: When it is winter, day and night may not be active.
The fourth variable "Stop" should be triggered by toggle switch that sends central main event.
One klick should call "Stop", where "Stop" have to turn off all devices.
Another click should run script for "Day", "Night" and "Winter" again.
This is only for cleaning filter manually and turn off all connected pump.
Here is my first Script for calculating "Day" and "Night":
Script for central scene event is:
Here I tried to set global variable "Stop", stop script #10 (see below) and call all devices to turn off.
Main script for connected devices is this one:
For every step is asked device if it´s already turned on or off to get better debug and to prevent that always be sitched if not necessary.
I know that my scripts are not coded well. These are my first steps with LUA...
I hope that you can help me to program my scripts properly, to include the calculation of the temperature and I am grateful for your ideas and suggestions.
Benjamin
