How to Fix Global Variable NaN?
I am setting Global Variable value by using api.post, but rarely I found that the Global Variable will become "NaN" value after posting through the api. I wonder why does it happen and how can I  use api.delete to delete it from Virtual Device rather than delete from the Variable Panel? It keeps error when I use the delete api.
Thanks a lot.
The same (
