How to test if device is enabled and visible?
I am looking at the HomeTable LUA code and I see that it uses the following line to get a list of enabled and visible devices:
     devices=fibaro:getDevicesId({visible = true, enabled = true})
I would like instead to get a list of all devices and log whether the device is enabled and/or visible. I do not seem to be able to find a way to get the value of the enabled/visible properties of devices. The below calls all return nil which is different to what I see in the device properties when calling the REST API /api/devices:
     deviceEnabled=fibaro:get(i, 'enabled')
     deviceEnabled=fibaro:getValue(i, 'enabled')
     deviceEnabled=fibaro:isEnabled(i). -- is not valid function
Can someone please point me to some examples or documentation that describes how to do this?
