LUA scene for set variable of hour
Someone can help whit a LUA scene that set a variable each hour.
I made a variable whit 24 values ( Example: Curent hour whit this values.  Hour 00:00, Hour 01:00........Hour 22:00, Hour 23:00)
Now i need a LUA code that set this value on certain hour. (if system hour is 22:00 to set value to "Hour 22:00")
In this moment i have 24 block scenes that set this variable, i want to reduce them to only 1 LUA scene.
Thank you
Thank you
Non-drifting loop. Will set global exact on the hour.
Set scene to Run scene: Automatic
    I do not know how to thank you!
    I will try and come back with feedback.
    LATER EDIT: It's working perfect. Thank you again!
    Edited by MDC
