Pcg 0
Hi All,
I bought 5 Fibaro motion sensor FGMS001. 3 of them was updated fine to version 2.8 and work fine, but the last 2 cannot be updated from version 2.7 to 2.8. I tried every suggestion from forum, (place at 20 cm from hc2, use external 3v power supply, stop the scene that use motion sensor, soft reconfiguration, remove and add again, restart the HC2).The behavior is strange, sometime the update fail in the first step, other time pass the first step and stop before final.
I mention that I use HC2 - 4.540 version and the first 3 sensors was updated with HC2 version 4.530. I use 30 fibaro devices, multiple scenes and virtual devices without any other issue.
Could you please, confirm if someone have the same problem and if you found a solution ?
Best regards,
Cristian
Edited by PcgMistake
3 answers to this question
