Dear all,
I'm using this script to pause my SONOS VD 63 and 65..... As you see, I just repeated the whole code for both. ;-)
There are some more SONOS VD's in my house. So I don't want to repeat the code for every VD. I'm sure there is a better way to make this with a FOR syntax. Could someone help me for that?
Thank you very much!
Dan
5 answers to this question
    .....nobody can help? :-(
    Hi @Danielos ,
    You don't really need to use above code to control Sonos remote VD. All you need is a table of Sonos VD ID numbers and then loop through that table and press needed button or set volume slider on the VD. Here is example of changing volume of all Sonos speakers to 10% volume:
    Same is with pressing buttons, you can stop all Sonos speakers with following code:
    Also can start playing if you set buttonID to "7". Of course all above is valid for Sonos Remote VD from @Krikroff.
    Enjoy coding :-)
    Edited by Sankotronic
    Replaced hc with fibaro
    @Sankotronicthank you very much!!
    Unfortunately, I receive an error...
    With that script:
    Any ideas? Thank you so much!
    Dan
    Hi @Danielos ,
    I have corrected scripts in my previous post so they should work now. You don't need part of code from local _f = fibaro to _f:call(sid,"pressButton", bid) since my code does not use that approach, my scripts press buttons on VD directly.
    In all my code I use at the beginning:
    and then I can write Fibaro functions with hc instead of fibaro as in bellow example:
