Hello
I have the shelly 1 and i can't integrate with HC Lite as a VD, any solution?
5 answers to this question
11 hours ago, celso bastos said:
Hello
Take a look at this!
Please take a look at
  here you will find a manual (Dutch) and instruction video.
I do have the same question / problem with setup a Shelly 1 on my HCL as a virtual device.
I've seen the above mentioned video. I must admit my Dutch is not too good but I don't see a real HCL setup there. I believe that video has been made on HC2 maybe.
So, is there anyone who have a Shelly1 setup on HCL as virtual device?
See my setup below. All looks good but Selly1 does not respond to any ON/OFF commands. Tested with HTTP commands from browser works fine.
/monthly_2021_10/image.png.1ba1e69104f54f788a27bc808eeaafad.png" />
Well-well-well.... never give up... I could just setup my two first Shelly1 VDs on my HCL... both work perfectly.
I deleted the earlier setup ones and started from the scratch using Domotica's links and files...again...  and now it works.
Not sure what was the issue before... it's setup like this:
IP address: IP address of Shelly1 device
Host: IP address of HCL
Even wait for device response checkbox works... Fibaro gets and shows the status of the device (On/Off)
So, good luck!
/monthly_2021_11/image.png.9cc1fbd650773117b9f0a639473b4a1c.png" />
