Redeemer 2
Hello guys,
I need a little help to "simplify" a LUA scene I've created (very noob in this):
I have a scene triggered by the netatmo rain gauge that lower my shutters (the open ones) to 22% (rolling shutter 2) when the windows are closed (door/window sensors) or to 1% when the windows are open, this last command has a 20 seconds delay for the balcony windows (so you have the time to come back inside the house). Then reopens them when the rain lowers under a certain value for 30 minutes.
I have created a series of "if, then, else" statement for every single shutter/sensor couple, and they work fine. Then I discovered the "tables" and "pairs", so I wanted to rewrite the script using this system with a "for" loop, but I don't know how to retrieve rolling shutter ID to the corresponding Window sensor ID to trigger the command.
I know I will need two sets of loop (one for the normal windows and one for the balcony ones) because of the 20 secs delay
Can you please help? This is the full script I've created.
