marcin12 0
I have a problem with installation of the Dimmer 2 device - I can turn on the connected LEDs but I unable to turn it off using connected switch (no response to turn off). However, both switching on and off work without a problem using the application (z-wave).
So there is a problem only with the use of a connected switch.
I can not deal with this problem, my electrician does not either
Could it be related to insufficient LED power? Will then connecting the bypass solve this problem. I will emphasize once again - switching on / off using the application works without a problem.
The second question - my LEDs are only 3W, and still work (through the application) with Dimmer 2. Is the use of a bypass still recommended in this configuration?
The third question - I am using in my HA also Double Switch 2 devices, which I use as main light switches (all light circuits are connected to them). In my case, the Double Switch works just as well when 1 x 5W light is on and when all lights (~ 800 W) are on. According to manual it shouldn't work. Why it works?
And last question - directly to the vendor - why does FIbaro have such a poorly developed network of installers in Poznań? I'm from Poznan, I can reach to the Fibaro headquarters in 10 minutes. I can not find a Fibaro installer for half a year.
6 answers to this question
