Garage and gate door control
dpopovic
Anybody uses Fibaro Roller shutter 2 to control garage or gate door?
I have several FGR222 free and I thought that I will be able to control my Horman garage and gate motors but it seems that nobody uses it.
Here I found only explanation how to use Fibaro SWITCH to do that.
4 answers to this question
@dpopovic The thing is most gates and garage doors come with controllers already that only require a dry contact  switched to operate.
So roller shutters features therefore are not required. A simple relay switch suites the job better.
  • I understand this but I already have 4xRoller Shutter devices which claims to do that.
    Now I need to throw them away and buy new switches.
    I use 2x roller shutter 2 in gate  mode, including IR/light barrier to stop movement if beam is interrupted, think works nicely.
    It's all in the manual of the roller shutter how to install.
