Dear all,
I'm facing a little problem with a lua script in a scene.....  the result is always a Unknown exception: /opt/fibaro/scenes/67.lua:10: attempt to index global 'Net' (a nil value)
So I read that I need to use the net.HTTPClient instead in a scene but I'm not able to rewrite the existing code of my working VD-button.
Could someone help me? That would really be brillant!!!
Thank you very much for your help...
Dan
Edited by Danielos
added things
9 answers to this question
47 minutes ago, Danielos said:
Dear all,
Dan
This could work
    @jgab thank you very much! But unfortunately, I think it doesn't work...
    I added a fibaro:debug("test") in the handleResult-function to check if the system handles the results. And no "test" is shown in the debug console.
    So I think it never starts.......
    Any ideas?
    Thanks!
    Dan
    Any ideas?
    So, nothing at all? Add some more debugs, but I suspect it hangs on the request.
    @jgab nope... my newest version of the script:
    And the results in the debug:
    So the "IST GEGANGEN" debug is never shown what means for me, the function didn't run. What do you mean?
    I think the requests never terminates (which makes the handleResult never being called)- Try to set a shorter timeout and see what happens
    In handleResult there is an error referencing response instead of result in gmatch (but that's not your main problem)
    @jgab ...
    2 minutes ago, Danielos said:
    @jgab ...
    Ok, your web server returning the realtime.csv is cooperating that the right way - any chance to debug that? I guess you tried to surf to "http://192.168.178.31:80/realtime.csv"and it works?
    Do you need credentials to access the url? username/password?
    If I run
    with a test.csv file on a local web server that looks like
    I get the output
    @jgab a good question.... I'm configuring that for a friend of mine and I can't open the browser on his computer. But I know that the VD-script from my first post is running perfectly, so I don't think that there are credentials or something else needed.
