Hi All,
I have a HC2 which has been stored away for a couple of years. Now that I have got it back out and turned it on, the firmware is still at 4.11.
For some reason no updates are showing as available. Or I am looking in the wrong place.  Anyone have any idea?
Also, on my android app it's only connecting remotely and won't connect locally.
Amy help would be appreciated,!
Pt
5 answers to this question
@Peter13 did you already try to reset the HC2 to factory defaults?
    If I reset to factory defaults, will I lose all my data?  Or can i upgrade then perform a recovery?
    I don't have experience with this, I thought if you stored it away ... you didn't use your HC2 anymore :)
    I hope someone else can answer your question.
    @Peter13 , do you have FibaroID?
    Are you logged in as a SuperUser?
    Can you share a screen shot showing Configuration -> General? Cover the sensitive data.
    " to "
    Temat został przeniesiony z "
    " do "
