any news regarding Air Conditioners... Fujitsu, Daikin, Mitsubishi?
Hi all,
I have been reading an hour here and I can't find a "standard" way for controling Air conditioners. Could you please help me to sort this out this info?
I would like to buy some machine, but I preffer to make something more standard. What I have learned here is that:
- Almost any brand doesn't have API REST support. --> Is that correct?
- Some brands are not using standard IR codes, so it is not possible to control them by Globalcache, Remotec, Broadlink RM2, mini...)  --> is that correct?
- There are some middle-point equipment that make like gateway due this lack of standards, like
My ideal goal would be to control easyly from a VD from Fibaro... If not, I can try to control it by Broadlink RM2, but I guess I will lose some a lot of useful thiings like back return information etc.
Do you recommend any brand in particular? I need to start from scratch so I would really like if you can share with us your advice :-)
Thanks a lot in advance
Edited by dimae
4 hours ago, NovaG said:
I'm using a Broadlink bridge, so it sends the IR commands. I use a HCL. Why do I need crypto?
Sir. i wrote own VD in L:IA what can working _directly_ (sic!) with broadlink, yes without BRIDGE. but for this VD req some crypt function whot can't be implemetred on pure-lua.
I am using two Mitsubishi  AC MSZ-LN25VGW-E1/MSZ-LN60VGW-E1 and it took me a
while to get it connected to my Intensis.
The original VD is by Daniel
/monthly_2022_02/image.png.2551d12d1c349d52acf01a5e66a213dc.png" />Corado Spain.
I did some small adjustments for my self. For those you like to use it, here is the VD attached.
IP is the IP adress of your Intenesis device in your LAN and TCP Port is 3310.
Using HC2
