FSE 34
Getting @Sankotronic code and modified to fit with AirVisual API (
), I can proudly introduce the first version of AirVisual AQI (Air Quality Index).SPECIAL THANKS
to @Sankotronic for original code of weather forecast VD
AirVisual VD Description
AirVisual VD is on standalone version till now. The idea is to be added as part of UHAS. It comes with community AirVisual API. I hope to get some tests on Enterprise AirVisual API and include data for owners of AirVisual Pro device.
The features that this version includes are:
/monthly_2019_05/image.png.e7e89d7c03cff0c4fe2c02b9e8536e1c.png" />Most of the changes that have to be done are placed on the top of Main loop of VD
You need to register an account to airvirtual.com and create a new API key. After add it to the following line
Select if you like to get coordinates by HC2 settings or manual
Select your preferred language to display on VD GUI. If you leave it blank, English will be selected.
Select the time of day that you like to get information by popup/push. In Community Edition you will not get any forecasts.
Here you can set preferred time format
Configure the id of every icon. It is recommend to use HC Icon preview VD.
There is only a part for user configuration on notification button section.
remove comment if you like to use HomeTable for identify mobile deviecs
Add the device id inside the brackets that you like to get popup/push messages
Select if you like to send push messages and popup messages..
That's for now, more to come. Waiting for your feedback/improvement comments!
Best Regards,
Zacharias
Edited by FSE2 answers to this question
