knuth 29
After having done a few scenes (LUA scripts) I am a little confused by some of the options offered by the HC2 interface. Here are three examples:
1. The overview
/monthly_2019_05/image.png.a1da0bb8051527cdbcd5716814e81a47.png" />Some of this is obvious, like the scene name and the number of instances currently running. But why do the last two scenes, both running, show different run/stop buttons? And what does the on/off slider signify? I have successfully started scene 3, even though it shows "off". I have also tried to set it to "on", but it goes back to "off". Question: How are these two buttons, on/off and run/stop to be interpreted and used?
2. The detailed view
This view raises several questions:
Category: Is this category ever used for anything?
Max running instances: In my LUA scripts I normally include tests like this: if fibaro:countScenes() > 1 then ... to abort the script if more than one is running. Does that make this number insignificant?
Run scene Manual/Automatic: The trigger in the LUA script (or a lack of trigger) dictates how the scene is started. For a standard manual script without trigger, what difference does the man/auto setting make? And for a script with %%autostart is it necessary to set the Run scene selector to Automatic as well?
Do not allow alarm...: My interpretation is that all scenes that are alarm related should check this box, all other scenes should not. By alarm related, I mean scenes that are triggered by an alarm. Is this good practice?
Edited by knuth2 answers to this question
