json.decode - Need to escape characters but can't get it working.
So I'm trying to pull a pice of information from a json reply but I need to either use [0] or .. in the string, both of which will not work. I've tried escaping them with a "\" but they still fail.
The line can either be response[0].id or response..id
This is the entire string...
Any ideas?
Edited by Desmo
8 answers to this question
Any ideas?
Can you post the json string?
    Just edited post to include the entire string :)
    It's the first "id" in the string I need.
    Edited by Desmo
    OK, that works in the sample but how do I get the double [[ & ]] to each side of my response?
    Here is my code (with some details extracted)
    It's the "response.data" I need to collect and add the double square brackets to. I had a quick go but nothing was working.
    Thanks again.
    Thanks again.
    The [[..]] is just a multi-line string quote.
    We could do just
    This (the 'str') is what you get in your response handler
    This is so strange....I'm absolutely sure that's what I had before but obviously not. I was on the right track but obviously had the syntax slightly wrong somewhere so thanks for tidying that up. Just one remaining problem now...the result is a little odd.
    The json result shows this...
    34646001298457174
    But it's turned in to this when I pull it out from the result...
     3.4646001298457e+16
    34646001298457174
     3.4646001298457e+16
    Its the same value, just different printed representations.
    If you print it with
    I still couldn't get the "id" working but found that "id_s" has the same value and works fine so I'm all set up.
    Thanks for your help with this @jgab :>
