[Question] Change VD name by button press
Greetings,
I try to change the name of VD by pressing a button of same VD if new name is configured.
It works OK changing the VD name but after that, it did not perform any output (fibaro:debug) of change was performed on debug window. it seems a bit strange. Can someone confirm this ?
27 minutes ago, FSE said:
Greetings,
If you do an api.put for a virtualDevice you also kill the running (button) handler (or main loop). If you do an api.put for a scene you kill all running instances of that scene.
Why they have to do it when changing a property I don't know. I can understand the need when the lua code of VDs or scenes are updated.
