sarf77 11
Hi all,
The code below forms the beginning of a scene where I only need my staff to populate the ID numbers of any qty of lights up to a maximum of ten and then the rest of the scene references those ID numbers.
The scene is working well but lets say I only have 8 lights (as below) what can I put in between the brackets (as below) that will not create an error. Almost like a 'dummy" number if you will. Keeping in mind the code then calls for the value of that ID further down.
local light1 = (98) --garage flood--
local light2 = (114)--dining pendant--
local light3 = (159)--family room--
local light4 = (109)--backyard--
local light5 = (64)-- kitchen--
local light6 = (69)--island bench--
local light7 = (36)--lounge--
local light8 = (81) --toilet--
local light9 = () --name here--
local light10 =() --name here--
local light1v = tonumber (fibaro:getValue (light1, 'value'));
local light2v = tonumber (fibaro:getValue (light2, 'value'));
local light3v = tonumber (fibaro:getValue (light3, 'value'));
local light4v = tonumber (fibaro:getValue (light4, 'value'));
local light5v = tonumber (fibaro:getValue (light5, 'value'));
local light6v = tonumber (fibaro:getValue (light6, 'value'));
local light7v = tonumber (fibaro:getValue (light7, 'value'));
local light8v = tonumber (fibaro:getValue (light8, 'value'));
local light9v = tonumber (fibaro:getValue (light9, 'value'));
local light10v = tonumber (fibaro:getValue (light10, 'value'));
