I recently bought a Dome motion/lux sensor. On their instruction manual, it gives detail on configurable parameters for the device, value has to be hexadecimal number. The issue is in HC2 when you add parameters manually, it won't take any letter in the value column, and when I put in decimal number as value, it says undefined after saving.
Any help would be highly appreciated.
Convert Hex to Dec and then fill in?
