I'm not sure if many people know this but Fibaro HC's API supports fully updating a virtual device through the API.
Introduction
This tutorial works with both the HCL and HC2 as it's pure HTTP commands no LUA involved.
Everything can be updated on the fly using the following URL.
Simply issuing a PUT command to this URL will update the virtual device.
We will send the data as JSON, so set the header accordingly
For the purpose of this tutorial we will need two tools.
this will dynamically create the buttons for us and push it to Fibaro
this will be used to get the favorites and send the actions back to the Sonos device.
Limitations
Due to the way Fibaro issues HTTP commands no special characters can be in the URL.
To get over this we send a POST command to Node-Red which forwards the command back to the Sonos API.
Results aren't displayed instantly refresh the Fibaro page or close and re-open the app to see the changes.
Assumptions
This tutorial assumes that Node-Red is setup and running.
Sonos API is setup and that Sonos has favorites added.
Sonos API and Node-Red are running on the same IP.
Fibaro has a virtual device setup and you know the id of it.
Fibaro
Go to the Fibaro Docs page to get the body of the virtual device we want to modify.
devices > GET /devices/{deviceID}
For this example we are going to use deviceID 67.
Click TRY IT! and copy the results into notepad.
Node-Red
Add a inject node (this is just a push button, so for now we don't need to configure anything with it)
Add a http request node with the following properties
This node will then pull all the favorites from the Sonos API.
Add the change node next (this is where all the fun happens)
Rules (click add after each one)
  • Move
msg.payload
to - msg.sonos (this moves the favorites to a separate object for easier use)
  • Set
msg.ip
Node-red-ip (click the down arrow and choose number this is where we will send all the commands to)
  • Set
msg.port
1880 (set this to the port of node-red on your pc)
  • Set
msg.port
  • Set
msg.device
67 (this example uses 67 - use the correct one for your scenario)
  • Set
msg.headers
{"Content-Type":"application/json"} (as mentioned above)
  • Set
msg.payload
click the down arrow and choose expression and then click the three dots (this contains all device properties)
The JSONata Expression editor is a very powerful JSON builder which will help us build the buttons we want.
Copy the device properties that you got from the Fibaro step into the editor window and remove the rows section.
You should be left with something similar to this.
As you can see some fields are different.
Replace the ip value with $$.ip this will then get the IP address we assigned above.
Do the same with port. Now everything should match.
Then copy the below rows section after "visible": "true",
$v is the each favorite value, $i is the index of each favorite and $a is the original array.
What is happening is it is iterating each object in the array and increasing the id by 1.
Caption is limited to 35 characters so it trims the caption to fit.
The name cannot contain any spaces so they are removed.
As mentioned above it is assumed that node-red and sonos api are on the same IP if not create another property called msg.ip2
The msg value contains the actions that will happen when the button is pressed
If ip2 exists change the last two occurrences of $$.ip to $$.ip2
The converted msg value looks like this
The full msg.payload should look like this
Connecting Node-Red to Fibaro
Create a HTTP request node
Change the HC-IP to the correct value but leave device as {{{device}}} this tells Node-Red to use the variable we already setup.
Add a debug node and link all of them up.
Press the button on the inject node and if everything works you should see the message in the debug windows with the new device properties. If it doesn't then retrace your steps to see where you made a mistake.
Sending Node-Red commands to Sonos API
Once everything is working and the buttons are showing we can get Node-Red to pass the commands to Sonos API.
Create a http in node (this will receive the command from fibaro with a payload of the favorite and room)
Link it up with a http response node with a status of 200 (this will just report that it's always a success)
Add a change node
Rules
  • Move
msg.payload.url
to - msg.url (this sets the url to the favorite we want to change to)
Add a http request node leave everything as default as it will be passed from the change node.
Add a debug node and if everything works it should show success.
If everything works tap yourself on the back for a job well done. It's not an easy process but it can be done.
Please let me know if I have missed steps or something is not working for you. If required I can provide my flow but I would prefer not to.
Edited by NovaG
Add full msg.paylod
btw you can use
 for call Fibaro and call VD
    Thanks @10der I know about that too.
    Was this tutorial helpful or did you know about how to do it already?
    3 hours ago, NovaG said:
    Dynamically created controls still make a some troubles for HC2.
    We should be careful with it, cuz sometimes created or deleted dynamically VD’s can stuck in HC2 core.
    Just for you info
    Thanks. What does that mean stuck in the core?
    I have a HCL.
    I have a HCL.
    Zombies processes etc
    as I can understand when you modify VD HC not modify correctly internal vars references on VD sections etc
    so, create VD dynamically once - OK
    but re=create VD ie modify VD dynamically “on fly” - sometimes is not safe. Alas
    Ok. So was this tutorial a waste of time?
    Yep. Thank you
    JFYI
    No, it's not a waste of time.
    You have a HCL so this is a great hack for you, and can inspire others. And if you don't have issues with "stuck in core"
    , I see no problem.
    Reading your tutorial gave me some ideas (I'm not that deep into node-red yet) that I will try out in the future.
    Thank you for contributing to the forum - and please continue to do so.
    Oh, and I don't mean 'hack' in a negative way - 'hacks' are the only way to get around the limitations of this box :-)
    Thanks @jgab that's all I want I got disheartened by @10der comments.
    But if I help someone even just a little bit it's worth it.
