Dear all,
Pls help me for situation.
I'm try to intergate Sensibo (Smart IR for Air Conditioner),
But I got the problem when connect via Fibaro Virtual Device as:
1. With Web Browser it work.
2. But I don't how to it work in FIBARO Virtual Device, I tried but it error?
local http = Net.FHttp("home.sensibo.com",80);
local Command  = '/api/v2/users/me/pods?fields=*&apiKey=O7LHDg0TID80NUyY0xqaqlGGlycqfg';
response ,status, errorCode  = http:GET(Command);
fibaro:debug(response);
fibaro:debug(status);
fibaro:debug(errorCode);
=> Error:
[DEBUG] 18:46:21:
403 Forbidden
nginx
1st : http (ssl) doesn't work in VD
2nd:
should be
local http = Net.FHttp("home.sensibo.com",443);
but see 1st point.
total: you can't. all thanks to Fibaro devs who can't develop https connection in 2019y.
as workaround write scene and call this scene from VD
make in scene params and call from VD scene with params (for example turn on off etc)
    Thank you @10der
    I got your information, with scenes it work without any problem. (of course using  net.HTTPClient)
    Edited by cuong.mhome
    @cuong.mhomecould you show me you'r Scene?
    I get the part of VD not working with https.
    But I dont understand your last post.
    I dont understand API's and how to get data etc :-)
    Hi @Ibie
    It's mean I have to write program on Scenes.
    So, now I connect with Sensibo use VD make the interface and scenes to write the code.
    By the way, I give some code. (It work for me):
    Hope it can help you.
    1. Get the Sensibo Status:
    function UpdateStatus(SensiboId,apiKey)
      local http = net.HTTPClient()
      http:request('https://home.sensibo.com/api/v2/pods/'..SensiboId..'/acStates?fields=status,acState&limit=1&apiKey=' .. apiKey, {
          success = function(resp)
            if resp.status == 200 then
                jsonResp = json.decode(resp.data);
                  local Status = "Off";
                  if ( jsonResp.result[1].acState.on == true) then
                      Status = "On";
                  local TargetTemp = jsonResp.result[1].acState.targetTemperature;
                  local mode = jsonResp.result[1].acState.mode;
                  local fanLevel = jsonResp.result[1].acState.fanLevel;
                  local tempUnit = jsonResp.result[1].acState.temperatureUnit;
                  local Swing = jsonResp.result[1].acState.swing;
                  if(TargetTemp == nil) then TargetTemp = "" end
                  if(mode == nil) then mode = "" end
                  if(fanLevel == nil) then fanLevel = "" end
                  if(tempUnit == nil) then tempUnit = "" end
                  if(Swing == nil) then Swing = "" end
                  local displayStatus = "Pow:".. Status .. ", Set:"..TargetTemp.. " " ..tempUnit;
                  local displayMode = "Mode:".. mode ..", Fan:" .. fanLevel .. ", Swing:" .. Swing;
    2. Set Value to Sensibo:
    ------ Set AC State ----------
    function SetProperties(SensiboId,apiKey,properties,value,isString)
      local myJson = '';
      if(isString == true) then
          myJson = '{"newValue": "'..value..'"}';
      else
        myJson = '{"newValue": '..value..'}';
      fibaro:debug(myJson);
      http:request('https://home.sensibo.com/api/v2/pods/'.. SensiboId .. '/acStates/'..properties..'?apiKey=' .. apiKey, {
              error = function(err)
                fibaro:debug("Error : " .. err)
            end,
            options = {
                method = 'PATCH',
                timeout = 5000,
                headers = {
                    ["content-type"] = "application/x-www-form-urlencoded;"
                data = myJson
                fibaro:debug("Respone OK")
    Hi @cuong.mhome ,
    Nice work. I plan to do integration of Sensibo Sky in near future. The thing is I still don't have AC unit :-D
    Is this working also on HCL as virtual device?
    @cuong.mhome
    Could you share the complete VD you have for the Sensibo ?
    I am struggeling to get your code complete, like where to input the API key and PodID
    Hopefully you could share a bit more.
    Dear Rwijbenga,
    Here is full Scenes:
    @rwijbenga post error, I don't know but Fibaro forum error, I can't post the code or attached VD file.
    Sorry.
    I try to post Scenes Code again.
    local apiKey = "Your API Here"
    local LinkVitualDeviceId = 650;
    local SensiboDeviceId = "Your Sensibo Serial"
    function Main()
          strCmd = fibaro:getValue(LinkVitualDeviceId, "ui.lblCmd.value")
          if(strCmd == "") then
            UpdateMeasurement(SensiboDeviceId,apiKey,LinkVitualDeviceId);
            UpdateStatus(SensiboDeviceId,apiKey,LinkVitualDeviceId);
        elseif (strCmd == "On") then
              fibaro:debug(strCmd);
            SetProperties(SensiboDeviceId,apiKey,"on","true",false)
            fibaro:call(LinkVitualDeviceId,"setProperty","ui.lblCmd.value", "")
        elseif (strCmd == "Off") then
            SetProperties(SensiboDeviceId,apiKey,"on","false", false)
         elseif (strCmd == "Auto") then
            SetProperties(SensiboDeviceId,apiKey,"mode","auto", true)
        elseif (strCmd == "Dry") then
            SetProperties(SensiboDeviceId,apiKey,"mode","dry", true)
        elseif (strCmd == "Cool") then
            SetProperties(SensiboDeviceId,apiKey,"mode","cool", true)
        elseif (strCmd == "Fan") then
            SetProperties(SensiboDeviceId,apiKey,"mode","fan", true)
        elseif (strCmd == "Low") then
            SetProperties(SensiboDeviceId,apiKey,"fanLevel","low", true)
        elseif (strCmd == "Medium") then
            SetProperties(SensiboDeviceId,apiKey,"fanLevel","medium", true)
        elseif (strCmd == "High") then
            SetProperties(SensiboDeviceId,apiKey,"fanLevel","high", true)
        elseif (strCmd == "FanAuto") then
            SetProperties(SensiboDeviceId,apiKey,"fanLevel","auto", true)
        elseif (strCmd == "SwingOn") then
            SetProperties(SensiboDeviceId,apiKey,"swing","rangeFull", true)
        elseif (strCmd == "SwingOff") then
            SetProperties(SensiboDeviceId,apiKey,"swing","stopped", true)
        else
            SetProperties(SensiboDeviceId,apiKey,"targetTemperature",strCmd,false)
              return;
    --Funtion -----------------------
    ------ Update VD Value ----------
    function UpdateMeasurement(SensiboId,apiKey,vdId)
      http:request('https://home.sensibo.com/api/v2/pods/'..SensiboId..'/measurements?apiKey=' .. apiKey, {
                  fibaro:call(vdId, "setProperty", "ui.lblActual.value", "Temp: " .. jsonResp.result[1].temperature .. ", Hum: "..jsonResp.result[1].humidity);
    function UpdateStatus(SensiboId,apiKey,vdId)
                      Status = "On";
                  fibaro:call(vdId, "setProperty", "ui.lblStatus.value", displayStatus);
                  fibaro:call(vdId, "setProperty", "ui.lblModeStatus.value", displayMode);
    function SetProperties(id,apiKey,properties,value,isString)
      --local myJson = '{\"acState\":{\"on\":'..acState..',\"targetTemperature\":22,\"mode\":\"fan\",\"fanLevel\":\"low\"}}';
      local myJson = '';
      else
      http:request('https://home.sensibo.com/api/v2/pods/vEWHLeej/acStates/'..properties..'?apiKey=' .. apiKey, {
            end,
            options = {
                method = 'PATCH',
                timeout = 5000,
                headers = {
                data = myJson
    function SetACState(id,apiKey,acState)
      local myJson = '{"acState":{"on":'..acState..',"targetTemperature":22,"mode":"fan","fanLevel":"low"}}';
      http:request('https://home.sensibo.com/api/v2/pods/vEWHLeej/acStates?apiKey=' .. apiKey, {
            end,
            options = {
                method = 'POST',
                timeout = 5000,
                headers = {
                data = myJson
    Main();
    -----------------------------  Finish Program ------------------------
    I try to post the VD for Sensibo,
    It work together with the sceenes.
    @cuong.mhome Hi,
    Thank you for sharing sensibo integration.  My home has a number of sensibo sky. Right now I control each sensibo via IFTTT which is very limited. May I know how your scene work with the VD?
    I have been waiting for "true" integration of sensibo over a year ?
    Edited by Sirhideo
    function Main()
        else
              return;
                      Status = "On";
      local myJson = '';
      else
            end,
            options = {
                method = 'PATCH',
                timeout = 5000,
                headers = {
                data = myJson
            end,
            options = {
                method = 'POST',
                timeout = 5000,
                headers = {
                data = myJson
    Main();
    @cuong.mhome From my newbie lua knowledge the above code looks like a middleware which waits for different scene to parse the parameter into this scene, and then this scene connects to the sensibo API and do the things.
    If this is the correct understanding, could you please give an example of scene on how to let say.. press High button and 21 button?
    Hi @
    The code can't work in VD. (Fibaro problem) so We have to write the API code in Scenes.
    Problem is:  Scenes can't don't have the interface, setting ...
    => We use the VD file is the User Interface to controll.
    In this way, when you press the button, it will update the command label, and after that it will call the Scenes.
    I make the scenes like the CODE BEHIDE.
    On mistake in this code I forgot to change is: http:request('https://home.sensibo.com/api/v2/pods/vEWHLeej/acStates?apiKey=' .. apiKey,
    vEWHLeej is serial number, but it still in the function. => You should to change it.
    Thank you.
    36 minutes ago, cuong.mhome said:
    Hi @
    Thank you.
    @cuong.mhome , so after changing the serial number, the linked scene ID in your VD, in simple, for automation purpose, I can start to create a 3rd scene just to do let say
    if day == night then
          fibaro:call(sensiboVDID, "pressButton", X)
    then your VD will call the scene above for operation, right?
    Edited by Sirhideo
    @cuong.mhome I get it to work! thank you! I am wondering 2 things about the VD though.
    1) where is the code that update the Actual and Status label?
    2) the Command label only appear after pressing any button but then the value disappear?
    1. I just use function for update the VD stataus:
    => "function UpdateStatus(SensiboId,apiKey,vdId)"
    2. Yes, the command label use to trans the parameter to Scenes.
    After scenes get and action, it will clear the command status.
    @cuong.mhome
    Thank you for the explanation.  By the way, I would suggest you to remove your API key and the device_id on this post for security purpose, once again thanks!!
    Edited by Sirhideo
    Is this working also in Home Center Lite?
    Thnx!
    I am going to try this. :)
    Thanks for your mention.
    This is just test device, token also the sample.
    So, it is not problem to show.
    On 10/25/2019 at 10:46 PM, Sirhideo said:
    @cuong.mhome
