Sanity Check - a scene to help you set "sane" options on your HomeCenter
petergebruers
Before I start: I donate this script to the community, I hope it is useful and someone will pick up the development. In other words: this script is looking for a new owner.
That is the first reason why I post it in the "suggestions" section of the forum, and not in "Downloads". The second reason is... it would be awesome if this was standard functionality of HC!
You can save it as a scene, or use Zerobrane (use the search for unofficial way to run scenes on your PC).
What does it do? It loops over all devices and applies a set of "rules" and gives advice. I want to stress that: it is "advice" so you as a maintainer of your system have to decide if the advice makes sens. Let me give a few examples of the output on my system.
You know, the older devices do not report power, but you can add "declared power consumption" if you want that. I probably forgot to do that...
Depending on the power supply and the load, an RGBW can send too many power reports, which you probably don't care about anyway. Reduced network traffic and database growth.
Yeah, that is a bit of a weird one, but the advice is sane. But this is about some internal stuff of the HC software, the one that displays all available actions in the scene editor. You'll find it is missing this action but if you're like me you probably don't care.
I don't like the standard 30 minute batter spam mails... BTW there was a time, when you had to set this on each individual slave and the master to silence them all. I don't think that's still true, to be checked.
Similar to RGBW
I decided, for myself, sane values for wake up are between 2 and 8 hours. If it is longer, and the device is eg. on the ceiling, you have to wait a looooong time before it picks up your change. Unless it has a small or fixed battery, the gains above 8h aren't worth it. You can set your own limits BTW.
If you think this is useful or you're interested, good, I am glad you like it!
Now let me talk about the Achilles' heel(s). Some stuff is tested on all devices, but you have to FEED the database if it is device specific. It does not magically recognize your device. At the end of the script there is a big Lua table with all sort of settings. The second problem is: the code is very messy! This is because I wrote this script years ago, I needed it because I wanted to do a "full reset" of my network and I wanted to semi-automate part of it.
This script was shared with some forum members, you'll find them credited in the file. Thanks for debugging guys. Script released with "share alike license" so pick it up, enhance it and credit them...
Version 1.5.1 - 2020-04-08
    - Script can be run on a PC using "Zerobrane" and is compatible with HCL/HC2/HC3
      See
    - Added "FGMS001 ZW5 Motion Sensor, V2 (fw >= 3.3)" = 010F 0801 1002
    - Added "Wall Switch (1 channel)" = "0258 0003 108c"
  Version 1.5.0 - 2019-11-23
    - This version was not released to the public because of the announcement of HC3
    - Add option PrintProductInfo to display the "raw" productinfo, can be used in scripts, for example, a
      "set parameters script" can use this to verify exact type of a device and avoid writing
      parameters to the wrong kind of product
      Example of ProductInfo: Danfoss LC13 productinfo: 0,2,0,5,0,4,1,1
    - Fix FGS-223 parameter 54 should have been p 55. Thanks @szmyk.
    - Rename "Neo Coolcam" to "Neo" and add NEO_DS01Z D/W sensor
  Version 1.4.3 - 2019-10-09
    - Fix FGT-001 name
    - Add iBlinds
Edited by petergebruers
  • Like 7
  • Thanks 3
  • Add iBlinds, fix FGT-001 name in SanityCheck.1.4.3.lua in post #1
    • Thanks 2
    Thanks @petergebruers. Useful script.
    I noticed, that there is still problem with parameter 54 despite of this note:
    "Fix FGS-223 parameter 54 should have been p 55."
    Yes, by sending the whole json struct from the API to @petergebruers and kindly ask him :-) When he collects some info and can find some spare time, maybe he'll add it. :-)
    • 3 months later...
    So you say that I may want to ignore messages like this or go for soft reconfigure?
    /monthly_2020_02/image.png.6385c9ea8f57af4730bc4da5bfc9a5ff.png" />
    Will this message dissapear If I soft reconfigure?
    Thanks!
    By the way: I have "send emails on battery low" checked by default on all of my devices. Sanity check tells me to turn them off, but I have never ever received a single email on battery low... I always realized low battery when I logged in to the UI of HC2, or saw some devices lost connection - battery completely drained.
    Email messages work fine on other events, so that part is OK.
    Do I really have to uncheck it? Does it affect network load in any way?
    Just being curious...
    Edited by johndeere
    Ignore them, it means the script has no name and no special rules for this device.
    No, it will go away if you or someone else adds rules to the script.
    You decide.
    On older HC firmware, devices send one battery low email per slave device, per 30 minutes, so it really spams your inbox. I think 4.560-ish changes that to one per device per day, so it is less of a problem.
    Does not affect load in any way.
    I would still uncheck on one of the slaves (I think nowadays it will automatically uncheck other slaves of the same node, rerun script to verify) and instead run the "battery check scene" written by @Sankotronic or his VD
    • 3 weeks later...
    start your scene (HC 2 FW 5480 / your 1.4.3) gives me this message: [DEBUG] 08:02:00: 2020-02-26 08:02:00.528139 [ fatal] Unknown exception: /opt/fibaro/scenes/626.lua:388: attempt to perform arithmetic on local 'paramValue' (a string value)
    What do i wrong?
    Thank you in advance.
    What exactly are the parameters 50/52/53/ "Active/Periodic power/energy reports" of the Fibaro dimmers for?
    If I deactivate these parameters I cannot see any change in the behaviour of the consumption display. The displayed wattage changes after a few seconds even if the parameters are deactivated.
    I am looking for the reason for the delay of up to 45 seconds when eight Fibaro RGBW are switched by associations controlled by a Quibino Din Dimmer. A recommendation of the Sanity Check from @petergebruers is to disable the power reports to reduce the Z-Wave traffic.
    Which disadvantages do I trade off on this?
    Edited by Wegerhoff
    • 1 month later...
     thank you for this script ... I found it very useful :) ...
    Would you be willing to draft tiny HowTo define new devices in Database section ? or at lest how to add parameters for devices like this:
    this is Fibaro FGMS-001 ZW5 Motion Sensor for which I think I see definition in your script but do not have any idea how to add my own parameter to the check list :)
    just give me an example how to modify above to let say parameter 3 to be set to value 3 and parameter 81 to be set to value 10%.
    Based on example I think I will be able to add all the rest I need :)
    Some small hint how devices are identified and matched to Database would be also great ...
    E.g. I do have Neo Coolcam 1CH (EU) switches which are not in the DB and I would like to add association in group2 setting to be verified.
    Thank you very much in advance for a small guide :)
  • New version (previous one was 1.4.3):
          See
        - Added "FGMS001 ZW5 Motion Sensor, V2 (fw >= 3.3)" = "010F 0801 1002"
    Find the device manual, think about what is needed (eg turn down power reporting frequency) then add it (copy/paste an existing device for example)
    To Check the hex codes  "010F 0801 1002" against existing names... Some manufacturers mention these codes in their manuals. Also, you can verify if someone already added it to OpenZWave
    It seems v3.3 of that sensor is a new hardware revision. I've added it to the database.
    To be clear: this script does not set or modify anything, it only verifies against a rule and tells you to change it.
    Look at "[1536]={n="FGWP101 Wall Plug"," line 1265 in version 1.5.1 of the script for an example and line 420 and below for parsing
    The code is the documentation but in short, "v" means "exact (v)alue" and "vg" means "(v)alue should be (g)reater..." and so on
    I have to disappoint you... I never finished writing the part to really check association groups... Because with Z-Wave Plus there is not much to check.
    See line 100 of the code:
    Thank you very much .. as always perfectly clear and mega complete answer :)
    I understood everything with one small exception ... I still do not understand how to add new device to DB :(
    I looked at "FGMS001 ZW5 Motion Sensor, V2 (fw >= 3.3)" = "010F 0801 1002" you added ...
    So what I see on the github provided by you this is the following line:
    <Product config="fibaro/fgmszw5.xml" id="1002" name="FGMS001-ZW5 Motion Sensor" type="0801"/>
    so HEX should be decoded in the following way: first 4 chars (0101F) means "Manufacturer", second (0801) is "type", third (1002) is "id" ... simple :)
    but how does this corresponding to the DB in sanity-check script?
    when compared old and new DB you added:
        [4098]={n="V2 (fw >= 3.3)",
    so how come script "knows" that [4098] is a device with HEX "010F 0801 1002" ?
    or hex is not used by the script and simply name really matters ?  and number in [ ] is just an index ?
    As a first thing I would like to correct DB for missing Fibaro devices (seems new FW versions)
    so looking again at the site I should be looking at:
    <Product config="fibaro/fgfs101zw5.xml" id="1003" name="FGFS101 Zwave+ Flood Sensor" type="0b01"/>
    <Product config="fibaro/fgsd002.xml" id="1003" name="FGSD002 Smoke Sensor" type="0c02"/>
    the last one is smart implant:  <Product config="fibaro/fgbs222.xml" id="1000" name="FGBS222 Smart Implant" type="0502"/>
    Thank you in advance for a teaching me :)
    Edited by ciechom
    • 1 month later...
    Hello @petergebruers i've missed that post, thank you for this new update !
    I'll try it right now.
    @petergebruers This looks like an awsome script, thank you ?
    In the description i see it is compatible with HC3, however it fails on the fist debug.  Anything i am missing please ?
    Regards
