ok - where am I going wrong?
Can you help me understand what I'm doing wrong with my Fibaro Scene? I want to define a scene that triggers the light in a room when someone enters. There are conditions, which I'm using the AND clause for in my HC2 Scenes. Right now the Scene is built, but everytime I walk into the room, the light turns on! It's driving me nuts because I don't understand what I'm doing wrong. I want to build the following:
Trigger is 20mins before Sunset, on any day of the week.
  AND the House is Occupied (Global Variable set from the Alarm System being disarmed)
  AND This Scene has not been triggered before (another Global Variable)
If these trigger conditions are met - THEN
  TURN ON Room Light
  AND Set Global Variable for this Scene to having been triggered.
The idea is that I might already be in a room, with the lights off watching a movie. I don't want the lights to come back on every time I switch them off because this Scene gets triggered again. So I have another Scene that fires at 6am and resets the Global Variable "xxxAutoLightRun" back to "No".
Below is the LUA Code, can you help me understand what I'm doing wrong?
%% autostart
%% properties
498 value
%% weather
%% events
%% globals
HouseOccupied
OfficeAutoLightRun
local sourceTrigger = fibaro:getSourceTrigger();
function tempFunc()
if (
( ((currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 4 or currentDate.wday == 5 or currentDate.wday == 6 or currentDate.wday == 7) and os.date("%H:%M", os.time()+20*60) == fibaro:getValue(1, "sunsetHour")) and tonumber(fibaro:getValue(498, "value")) > 0 )
and
( fibaro:getGlobalValue("HouseOccupied") == "Yes" and fibaro:getGlobalValue("OfficeAutoLightRun") == "No" )
then
    fibaro:call(228, "turnOn");
    fibaro:setGlobal("OfficeAutoLightRun", "Yes");
setTimeout(tempFunc, 60*1000)
if (sourceTrigger["type"] == "autostart") then
tempFunc()
else
if (
( (currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 4 or currentDate.wday == 5 or currentDate.wday == 6 or currentDate.wday == 7) and tonumber(fibaro:getValue(498, "value")) > 0 )
and
or
then
The visual blocks for this LUA are below:
/monthly_2019_06/image.png.4d6765e688e5370171e7ccc360ebf6ad.png" alt="image.png.4d6765e688e5370171e7ccc360ebf6ad.png" />
Hei
@Chrisjcbt ,
here is a very basic setup with a few colors to show progress.
I assume you have another scene to reset OfficeAutoLightRun to no ?
%% autostart
%% properties
769 value
%% events
%% globals
HouseOccupied
OfficeAutoLightRun
Debug = function ( color, message )
  fibaro:debug(string.format('<%s style="color:%s;">%s', "span", color, message, "span"))
if (
 ( tonumber(fibaro:getValue(769, "value")) > 0  ----youe sensor id / set in headers also
      and ( ((currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 4 or currentDate.wday == 5 or currentDate.wday == 6 or currentDate.wday == 7) and os.date("%H:%M", os.time()+20*60) == fibaro:getValue(1, "sunsetHour")) )
      and  fibaro:getGlobalValue("HouseOccupied") == "Yes"
then
    fibaro:call(162, "turnOn");----your light id
    Debug('green', "HouseOccupied =Yes")
    Debug('green', "OfficeAutoLightRun =Yes")
else
Debug('white', os.date('%c'))
Debug('red', "Waiting for Sunset + offset :OfficeAutoLightRun =No")
Edited by MARCUSP.I.L
