HC2 4.543 - suddenly switch off
Hi Gyus,
I have update my HC2 to 4.543 on 04.06.2019.
Everythings go well untill i have change of scene yesterday night. After (approx one hour) this change i have found HC2 switched off. So i have swithed on by presing button. After time (aprox hour) again I have found HC2 switched off.
We have hot weather here in Bratislava nowdays, could be that system is overheated?
Do we have any know bug?
Should I restore to previous version?
Thank you very much for your advice
Peter
Overheating, yes maybe. You can set up a fan and see if it helps.
Also check the Diagnostics panel if the CPU load is normal (10-30%).
Also check the RAM if it increases over time. In that case, there may be some scene that fails.
