RikH 1
I build an alarm system with the HC2 with a couple of LUA scripts and everything is working smoothly.
I only have one thing to solve.
When I activate the alarm by using the Zipato RFID keypad my Hue lamp will give feedback if the alarm is set right (green or red).
In case of the red light I need to go back in, set the RFID keypad to the ' home ' setting, close the open door / window and use the keypad to set the alarm again.
Is it possible when the Hue lamp turns red, to unlock the Zipato RFID keypad automaticly? In this case I can go into the house, close the door, use the 'away' button and I'm good to go. Espacially for other users then myself it makes no sense to use the ' home ' button first
--fibaro:call(75, "unsecure")
fibaro:debug("Doorlock (before): " .. fibaro:getValue(75, "secured"));
fibaro:call(75, "secure");
fibaro:debug("Doorlock (after): " .. fibaro:getValue(75, "secured"));
I tried this code but this doesn't work. I use the device ' Door Lock ' for the Zipato Key pad.
Thanks for the help.
Kind regards,
Rik
4 answers to this question
