[Help request] mac2vendor scene
Greeting,
I try to get vendor name by MAC address on a scene. I get invalid arguments error without any results.
here is the code. Please help
Edited by FSE
10 answers to this question
Is it not just the typo finaro:debug instead of fibaro:debug
     I'm afraid it is not the problem. I fixed and I get invalid argument error on connection
    I see that the error is repeating in cloudflare served APIs. I suppose something is missing on Header section. Using Postman, responses are OK. even I tried another API to get vendor name from MAC (
     ). which is not https.
    Still help is needed @10der @jgab
    https is tricky on the HC2.
    This gives you the vendor name
    Still no response from macvendors.co API. Sir, did you checked on your HC?
    Yes, sir.
    hmm...it is strange. I double checked code. Still no response....the only thing may think is that I use 4.543beta . Fibaro Broken library?
    Upgraded to 4.543beta and it still works.
    function macvendor(macaddr)
    local http = net.HTTPClient();
          http:request("http://macvendors.co/api/vendorname/"..macaddr, {
          success = function(res)
              fibaro:debug('OK')
              fibaro:debug(res.data)
          end,
              error = function(err)
              fibaro:debug('Error : '..err) end
    macvendor("002248FF76B0")
    that is BAD news for me.... :(
    using curl from a linux box on same network, I get response so no issue with Cloudflare. Fibaro HC2 still no answer.
              fibaro:debug('OK')
          end,
    I downgrade to 4.530 and is working, from backup. When I upgrade to 4.540 +, there is no response :(
    Something looks broken on my HC2....
