francescosarri 0
Hi everybody
I'm a newbie with Fibaro and aim using Fibaro 223 relay to open a motorized window fitted with a chain window opener. I used this kind of relay on 7 roller shutters without any problem but unfortunately this seems to be not working with the electric window opener...
I tried to test it by using a Fibaro 222 relay and that is working... unfortunately it's not a clean solution as I can't have window positioning and have to switch on and off the 2 relays on 222 every time I want to have the window opened or closed
any ideas on what could be the issue and way forward?
thanks in advance!
Francesco
4 answers to this question
