gFIBm 0
I have an RS3 which works alright when included normally. Now I removed it from the network (I am using FHEM and a UZB stick as main controller) and re-included it securely. That basically worked, but I am now confronted with a somewhat reduced functionality:
The endpoints for slat tilting and blinds positioning no longer accept "dim" commands (it still works for the main endpoint), and they no longer list SWITCH_MULTILEVEL class, which I guess is the reason.
Is this normal, an FHEM bug or configuration problem, or an RS3 firmware issue?
